Vivo X50 Battery Specifications
| Detail | Spec |
| Model Number | B-N2 |
| Capacity | 4,200 mAh |
| Voltage | 3.87V |
| Charging | 33W FlashCharge |
| Connector Type | FPC (Flex connector on board) |
Step 1: Identify the Battery Problem
Common symptoms:
- Phone drains very fast (less than 3–4 hours screen time)
- Battery stuck at a percentage (e.g. always shows 50%)
- Phone shuts off even with battery remaining
- Battery swollen / back cover lifting
- Won't charge at all
- Charges very slowly
- Overheating while charging
Step 2: Software Check First
Before opening the phone:
- Go to Settings → Battery → Battery Usage — check which app drains most
- Turn on Battery Saver Mode
- Check Background App Activity — restrict apps running in background
- Do a calibration:
- Drain battery to 0% (let it shut off)
- Charge to 100% without interruption
- Repeat 2–3 times
Step 3: Check Charging Port & Cable
Bad charging is often NOT the battery:
- Try a different USB-C cable (original Vivo cable preferred)
- Try a different charger (33W Vivo adapter)
- Clean the charging port with a soft brush or compressed air
- Check for bent pins inside the port using a torch/flashlight
Step 4: Battery Health Check (No Opening Required)
Use these methods:
- Dial *#*#4636#*#* → Phone Info → Battery Info
- Install AccuBattery app → charge overnight → check battery health %
- If health is below 80% → battery needs replacement
