Use --no-shrink to test if ProGuard is causing issues.
Add missing proguard-rules.pro for all third-party libs.
Make sure proper initialization in main().
Check AndroidManifest for required permissions.
Use flutter run --release with USB to catch errors.
Match SDK + Gradle versions across environments.
In one of our fintech Flutter apps at Impero IT Services, release builds were crashing due to a subtle difference in Gradle versions across dev environments. We stabilized it by explicitly pinning compileSdkVersion, Gradle & kotlin_version across CI/CD and local builds.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
