the HEATZ HP65 Power Bank
Meet the HEATZ HP65: The All-in-One Powerhouse Your Gadgets Have Been Waiting For​
In a world where we're constantly connected, running out of battery is not an option. We juggle chargers for our phones, laptops, and tablets, and a forgotten cable can ruin a productive day. But what if one device could replace that entire tangled mess? Enter the HEATZ HP65, a 20,000mAh power bank that redefines charging convenience.
Based on its impressive packaging, this isn't just another portable battery; it's a complete, intelligent charging solution designed for the modern tech user. Let's break down what makes the HEATZ HP65 stand out.
Massive Power, Serious Speed​
The two headline features are impossible to miss: a colossal 20,000mAh capacity and a blistering 65W power output.
  • 20,000mAh Capacity: This is enough juice to charge a modern smartphone multiple times over, power a tablet for hours, or give a compatible laptop a significant boost. It's the perfect capacity for weekend trips, long flights, or just surviving back-to-back meetings without hunting for a wall socket.
  • 65W Power Delivery: This is the real game-changer. 65 watts is enough power to fast-charge not just your phone, but also high-demand devices like a MacBook Air, Dell XPS, or other USB-C powered ultrabooks. The ability to charge your laptop with a device this portable is a massive advantage for students and professionals on the go.
The Genius is in the Design​
HEATZ has clearly focused on eliminating clutter. The HP65 is built as an all-in-one charging hub.
  • Built-in Retractable Cable: Say goodbye to carrying extra wires. The HP65 features a built-in, retractable USB-C cable. At 85cm (28 inches), it's long enough to be practical, and when you're done, it tucks away neatly, preventing tangles and damage.
  • Integrated Wall Plug: This device doubles as a wall adapter! It has a built-in AC plug, allowing you to charge the power bank directly from the wall without needing a separate brick. Even better, it functions as a 65W wall charger for your devices when plugged in. The box also mentions it comes with two extra plugs and a UK plug, making it an instant travel-ready companion.
  • Charge 3 Devices at Once: With a built-in USB-C cable, a separate USB-C port, and a USB-A port, you can power up to three devices simultaneously.
Smart, Safe, and Crystal Clear​
Beyond raw power, the HEATZ HP65 is packed with smart features to give you peace of mind.
  • Digital LED Display: No more guessing games with blinking dots. A crisp, circular LED display shows you the exact battery percentage, so you always know how much power you have left.
  • Intelligent Protection (IC Protective): The power bank is equipped with a suite of safety features, including protection against overcharging, over-discharging, overcurrent, and short circuits. This ensures both the power bank and your valuable devices are kept safe.
  • Wide Compatibility: It supports a range of fast-charging protocols, including Quick Charge (QC2.0/3.0), AFC, FCP, and SCP, ensuring optimal charging speeds for a wide variety of devices from different brands.
Key Specifications at a Glance​
  • Model: HP65
  • Capacity: $20,000mAh$ / $77Wh$
  • Max Power Output: $65W$
  • Ports:
    • 1 x Built-in Retractable USB-C Cable (Output)
    • 1 x USB-C Port (Input/Output)
    • 1 x USB-A Port (Output)
  • Input:
    • AC: $100-240V$
    • USB-C: Up to $30W$
  • Output (Power Bank Mode):
    • USB-C (Cable or Port): $5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A$ (65W Max)
    • USB-A: $5V/3A, 9V/2A, 12V/1.5A, 10V/2.25A$
  • Features: Retractable Cable, LED Display, Laptop Charging, Multi-device Charging, Fast Charge Protocol Support
  • Weight: $422g$
The Verdict​
The HEATZ HP65 Power Bank appears to be a brilliantly engineered device that solves real-world problems. It combines the capacity of a high-end power bank, the speed of a laptop charger, and the convenience of a wall adapter into a single, sleek package.
If you're a frequent traveler, a busy student, a remote worker, or anyone who simply wants to streamline their charging setup, the HEATZ HP65 looks like the perfect investment to keep all your devices powered up, wherever you are.
