HONOR 50 BATTERY
The Honor 50 is powered by a Li-Po 4300 mAh non-removable battery, which supports 66W fast charging. According to Honor, it can charge up to 70% in just 20 minutes and reach 100% in about 45 minutes—pretty impressive for a mid-range device.
Replacement Battery Info​
If you're looking to replace the battery, here’s what you need to know:
  • Model Number: HB476489EFW
  • Capacity: 4300 mAh
  • Voltage: Typically around 3.85V
  • Charging Support: 66W wired fast charging
Buying & Installation Tips​
  • Availability: You can find original replacement batteries on platforms like Shopee Malaysia, ranging from RM85 to RM155.
  • DIY Installation: If you're replacing it yourself, make sure to dry test the battery and screen before sealing anything. Some sellers offer no warranty if the battery is glued in before testing.
  • Professional Help: For peace of mind, consider visiting a certified repair center to ensure proper installation and safety.
