SSD | HDD ENCLOSURE
RASCOTEC PNG
Member
malaysia
TRANSPARENT 2.5"HDD/ SSD
ENCLOSURE 3.0
USB 3.0 Speed | Support 6TB
2.5 External Hard Drive Enclosure makes it easy to connect your hard drive to a PC, PS4, or Xbox for backing up files or accessing videos, audio, games, and more from the hard drive.
With 5Gbps Data Transfer, the external hard drive enclosure offers transfer rates of up to 5Gbps via the USB 3.0 port, and up to 6Gbps with UASP protocol. It is also backward compatible with USB 2.0 or 1.1 ports, making it perfect for uploading large files quickly and efficiently.
MAX BTB & Universal Compatibility features Plug & Play functionality with no tools or drivers required. It supports Windows, Linux, Mac OS 8.0 and above, and works with 2.5" 7mm/9.5mm SATA HDD and SSD up to 6TB. Compatible with brands like WD, Seagate, Toshiba, Hitachi, Samsung, Crucial, and other SATA port SSDs and HDDs.
2.5 HDD / SSD
USB 3.0 SPEED
6GB/S
SATA -3.0
High Speed File Transfer
Support 6TB
Suitable for all 2.5" SATA HDD/ SSD Drives Built in PCBA entire board, hard disk can be perfectly fixed into the circuit board
USB 3.0 interface (Compatible with USB 2.0)
Up to 6GBPS data transfer rates
Model: ZL11
Product Type: SSD | HDD ENCLOSURE
Brand: HEATZ®
Manufacturer: Ashtel Group.
Made in China
