If you are looking for the CPU position of your Samsung a04 smartphone, you might be interested in this post. It will show you how to locate the CPU position.
The CPU, or central processing unit, is the brain of your smartphone. It controls all the functions and applications that run on your device. The CPU is usually located on the motherboard, which is the main circuit board inside your phone.
If you need to replace and reball the CPU of your Samsung a04 this picture will help you to find the position
