Poco F2 Pro
suneesh
Malaysia
[Poco F2 Pro Death Case]
* Diagnosis the problem step by step.
1.USB power reading with battery 👉0.000A
2.USB power reading without battery 👉 0.000A
3.PCB connect with power supply 👉0.027A 🤔
4. Auto reading 0.027 A That means short circuit 🧐
5. Separate the sandwich motherboard.
6.RF board ok Power board problem 😭😭😭
7.Diagnosis the power board [U5500-BQ25970] abnormal heating.
8. check around the (BQ25970) output nothing.
9.Remove (BQ25970) and check [ input -output]
Everything is normal. No short circuit ❤️❤️❤️
10.(BQ25970 not available, I use BQ25968) because there schematic are same. 🫣✅✅✅
11. The power board comeback to normal .
12.USB power reading without battery 👉 0.225A
13.USB comport ok
14.USB power reading with battery 👉 1.505A
15. Revive the motherboard and comeback to Life.
Finally The Case is closed 🔐 Game over successfully.
