- Messages
- 609
- Reaction score
- 24
- Points
- 18
EFT Pro Dongle Update V4.6.1 Build 001 is released :
What's New :
[Apple]
Update Remove Icloud Open Menu BY APPLE ID
Proxy Server: 51.178.81.232
Port: 8887
51.178.81.232:8887
[Rockchip]
Added New Boot By Loader
[MTK]
Added New Protocol MTK 2023
Read Info / Flash (Read + Write) / Format / FRP
Added New Tecno / Infinix/ Itel Preloader MTK
Auth Free MT6761 / MT6765 / MT6768
Read / Write Firmware / Reset FRP / Factory Reset
NOTE: Some Models have been tested and most brands and Models are Supported
MT6761
Infinix Hot 9 Play
Infinix Hot 8
Infinix Hot 12i
Infinix Smart 4
Infinix Smart3 Plus
Tecno Camon 11
Tecno Camon 12 Air
Tecno Camon iACE2
Tecno Camon iACE2X
Tecno Pop 3 Plus
Tecno Pop 5 Pro
Tecno Pop 6 Pro
Tecno Pouvoir 3 Air
Tecno Pouvoir 4
Tecno Spark 3
Tecno Spark 3 Pro
Tecno Spark 4
Tecno Spark 4 Lite
Tecno Spark 5
Tecno Spark 6 Air
Tecno Spark Go
Tecno Spark Go 2023
Tecno Tecno Spark 6 Air
Tecno Spark 8C
Tecno Pop 7 Pro
MT6765
Infinix S5 Pro
Infinix Hot 20 Play
Infinix Hot 30 Play
Infinix Hot 30 Play NFC
Infinix S5 Pro
Tecno Camon 15 Premier
Tecno Camon 15 Pro
Tecno Phantom 9
Tecno Spark 10 4G
Tecno Spark 9
Tecno Spark 9T
MT6768/MT6769
Infinix Hot 10i
Infinix Note 11i
Infinix HOT 12
Infinix Note 10
Infinix Hot 10s
Infinix Note 10
Infinix Note 12i 2022
Infinix HOT 12
Infinix Hot 20
Tecno Camon 20
Tecno Pova Neo 2
Tecno Pova Neo 3
Tecno Spark 8 Pro
Tecno Spark 8P
Tecno Spark 9 Pro
Tecno Camon 18T
Tecno Pova 2
Tecno Camon 17P
Tecno Camon 19
Added New Protocol For MTK (V5)
Read info / Flash (Read + Write) / Format / FRP
Read/Write Firmware / Reset FRP / Factory Reset
[HUAWEI]
Added New support For CHIP KIRIN
Read Info / FRP
KIRIN 620
KIRIN 650
KIRIN 655
KIRIN 685
KIRIN 659
KIRIN 710
KIRIN 710F
KIRIN 910
KIRIN 920
KIRIN 925
KIRIN 930
KIRIN 935
KIRIN 950
KIRIN 955
KIRIN 960
KIRIN 970
KIRIN 980
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Support Forced BROM (method 1)
Support Forced BROM (method 2)
Support Forced BROM without Test Point
Support Samsung forced BROM (PIT Method)
Support write Huawei (UPDATE APP) firmware
Support write Samsung (TAR) firmware
Support write Oppo/Realme (OFP) firmware
Support write EMMC Dump firmware
Support Vivo MT6765 PreLoader
Support direct unlock network MTK (BROM)
Support (Vivo) Disable MDM lock Supported for (2020 to Up)
Support (Vivo) Disable MDM lock Supported for (2019)
Support (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Support (Vivo) Disable demo mode
Support (Vivo) Disable orange msg
Support (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Support Security 2022/2023 for MTK
Support Device for MTK devices
Support Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
Fix Tool Dl Image Fail
Reset Frp Lock WriteFile
Protocol For MTK (V6)
Protocol MTK Devices Read Info / Flash / Format / FRP
Free Auth Tecno / Infinix / itel
Support Models on V6 Protocol Infinix / Tecno
[SPD]
Support models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
Read Info
Reset FRP/Factory Reset
Unlock Bootloader
Relock Bootloader
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
Remove FRP Direct (MTP) 2023
Enable ADB With Call Emergency #0#.
Remove KG Lock Direct (MTP)
Translate ADB Android 13
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Device Support for Qualcomm devices
Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Unlock ID (Huawei)
Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
BOOT PASSCODE/HELLO FOR (IPAD)
Read Account From Backup Folder
Boot Passcode/Hello IOS 11.x Up 16.x One Click
Change Test Signed Drivers to ON
Read iDevice Info (Recovery Mode)
Automatic Active Backup Restore built-in with One Click
supported by recovery and supported by DFU
Save info to txt file when Backup or reading from a file
Restore Passcode with Disable Update/Reset
Add option to format or restart if backup completes
Ipwnder restart in case of failure
Restore by bypass Setup and disabling Update
[ Rockchip ]
Update Read/Write Flash
Factory Reset & Frp
More Come Soon ...
Update online without replacing it ...
For New User Download File
