iPhone 7 complete charging and usb ways
You may need to check the charging and USB ways if you have an iPhone 7 that is not charging or connecting to a USB device. These are the paths that connect the charging port to the main board of the phone. Sometimes, these paths can get damaged or disconnected due to water, dust, or physical impact. To fix this problem, you will need to open the phone and use a multimeter to test the continuity of each way.
