- Messages
- 609
- Reaction score
- 24
- Points
- 18
Samsung a125f CPU pin out
If you are looking for the Samsung a125f CPU pin-out diagram, you have come to the right place. In this forum post. The Samsung a125f CPU is a quad-core ARM Cortex-A53 processor that runs at 1.8 GHz Chipset Mediatek MT6765 Helio P35 (12nm). It is used in some models of the Galaxy A12 smartphone. The CPU has 208 pins that are arranged in a grid pattern on the bottom of the chip. Each pin has a specific name and function, such as power supply, ground, clock, data, control, etc. To find out the pin out of the Samsung a125f CPU, you will need to carefully remove the chip from the motherboard and examine it under a magnifying glass or a microscope. You can also use a multimeter or an oscilloscope to test the pins and verify their functions. Here is a table that summarizes the pin out of the Samsung a125f CPU:
in this picture, the blue colour indicates no connection,
grey dot ground
picture from Borneo tool
| Pin Name | Function |
| VDD | Power supply (1.8 V) |
| VSS | Ground |
| CLK | Clock input |
| RESET | Reset input |
| IRQ | Interrupt request output |
| FIQ | Fast interrupt request output |
| AXI | Advanced eXtensible Interface bus |
| AHB | Advanced High-performance Bus |
| APB | Advanced Peripheral Bus |
| UART | Universal Asynchronous Receiver/Transmitter |
| SPI | Serial Peripheral Interface |
| I2C | Inter-Integrated Circuit |
| GPIO | General Purpose Input/Output |
| ADC | Analog-to-Digital Converter |
| DAC | Digital-to-Analog Converter |
I hope this gfcforum post was helpful to you. If you have any questions or comments, please leave them below. Thank you for reading!
grey dot ground
| VSS | Ground |
| CLK | Clock input |
