Huawei Honor X7 test point and complete the FRP bypass process
Huawei Honor X7 is a high-performance smartphone, it is equipped with Snapdragon 680 4G chipset, 6GB RAM and 128GB storage space. It also has a 6.74-inch full-screen display, a large 5000mAh battery, and a rear quad-camera system. In order to unlock the FRP (Factory Reset Protection) of Honor X7, you need to use the test point method. A test point is a special point on the phone's motherboard that puts the phone into EDL (Emergency Download) mode. In EDL mode, you can use Unlock Tool software to bypass FRP lock. The following are the specific steps of the test point method:
1. Turn off the power of the mobile phone and take out the SIM card tray.
2. Open the back cover of the phone and remove the battery cable.
3. Locate the test points on the motherboard as shown in the figure below.
4. Use a metal pin or wire to connect the test point to the ground (GND).
5. Open the Unlock Tool software on the computer, and select the model of Honor X7.
6. Click the Start button and wait for the software to complete the FRP bypass process.
7. When the software displays Success, disconnect the USB cable and reconnect the battery cable.
8. Restart the phone, and you can use Honor X7 normally
