Xiaomi Redmi Note 9
Xiaomi Redmi Note 9 loses signal​
Signs Redmi Note 9 has network problems
  • There is no network on your phone.
  • Low signal.
  • The phone only searches for the network but is not connected.
  • Constant bearish signals.
Causes of Redmi Note 9 network problems
  • Your SIM card might be faulty.
  • Your network operator may be experiencing a temporary problem.
  • The GSM antenna contact may rust or may get some dirt.
  • The contact lines of the antenna are incomplete with the contacts of the GSM antenna.
  • Any coils and capacitors of an antenna network or Power Amp IC can fail.
  • The secondary coil antenna may be faulty.
Fix Xiaomi Redmi Note 9 signal problems
  • Restart your Xiaomi Redmi Note 9 phone and check.
  • Remove and reinsert the SIM card and check.
  • Switch between different network modes and test.
  • Check if any other SIM cards are working and if your SIM card or network operator might be having problems.
  • Ways to solve network problems of Redmi Note 9 Jumper
