- Messages
- 609
- Reaction score
- 24
- Points
- 18
Added a new FRP Remove solution for OPPO phones with Qualcomm SoCs. It's available from EDL mode.
We can't provide an exact supported model list, because it's a generic solution which utilises a custom feature of the Qualcomm programmers.
Based on our current programmer database we've collected a list of the supported SoCs below. Please note: this solution might not work on every device that is equipped with the listed SoCs.
The new solution uses Oppo programmers from the official firmware packs, which are named like "prog_firehose_ddr_fwupdate.elf". If Chimera can't provide you a suitable programmer you can look inside a firmware pack and pick one manually. You can use Chimera's own Firmware Extractor (Utility) for this. Be aware that the procedure can take a long time to execute (10-15 minutes) and removing the phone during the process will make the phone unable to boot. This long process usually happens only once on a device.
You're welcome to post your experience and results in this thread. Please also share the model names for every successful procedure!
Software version: 34.41.1114
Release date: 2 January 2023
Visit our Webshop: https://chimeratool.com
- Qualcomm Snapdragon 450
- Qualcomm Snapdragon 460
- Qualcomm Snapdragon 662
- Qualcomm Snapdragon 680 4G
- Qualcomm Snapdragon 720G
- Qualcomm Snapdragon 750G
- Qualcomm Snapdragon 765G
- Qualcomm Snapdragon 865
- Qualcomm Snapdragon 888
